sgtsandman
Automotive Technician
TRS 25th Anniversary
- Mar 11, 2017
- Aliquippa
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3 EcoBoost
- Tire Size
- 265/70R17
- My credo
- Anything that can go wrong, will go wrong. Plan for it as best you can.
Duh, senior moment here, forgive me (One of the things I hate about being a dimwitted senior old fart is sometimes you think like a dimwitted senior old fart).
I bought this trailer and the 15 or 20 14” Ranger bullet hole wheels and axles, etc. 2 or 3 years ago. While I hadn’t even started, no less finished, the Road Ranger tractor at that time, I remember doing all the math in my head (therein lies the problem), so I wouldn’t have to modify this trailer. Remember that 3-4 times a week I arrive in my kitchen and I can’t even remember why I came down from the bedroom
When I did the mock up this afternoon, I was using a 15”, 235/75/15 spare tire from the semi. I had completely forgotten that I had accumulated all of these 14 inch wheels, most of which have 185/65/14 tires on them, which are about the same width as the rim. Truck tires are 15 inch and wider.
Soooo, I went back out to the tire pile next to the shed of miracles, and I dug some of these things out, and then I redid the mock up. With the 14s, and the 185/65/14’s, I can keep the trailer frame width as is, and I end up at exactly 70 inches to the outside of the tires, which is exactly the same as the Road Ranger.
View attachment 94662View attachment 94663View attachment 94664
The truck’s tires stick out about an inch outside the fenders. So I’m going to rethink the trailer, so the trailer tires do the same thing. I will still keep the tires underneath the deck of the trailer. This puts me back to probably stepping up the deck, quasi goose neck, so the deck rides level when it’s attached to the fifth wheel.
My underlying point is that I really did think this out very well, then I forgot it all, but that was a few years ago, and I forgot that I was smart back then. Something like that.
And yes, I have to cut out about 3 inches from the forward axle so it mirrors the rear axle. Project for another day. Second set of brakes later too.
Before you set the axles in place, are you going with the traditional center of balance for a trailer or the semi trailer center of balance format? If the semi trailer format, you may want to do some research on what the ideal C/B range is so you can figure out axle placement. And if you are going with that format, you may want to reconsider your coupler due to the heavier weights.
Your current coupler might work, maybe, with a traditional trailer center of balance (10% - 15% of total trailer weight on tongue) and the center of trailer horizontal rotation would be in the center of the axles where the equalizer should sit.
I considered going tandem axle on my trailer but the amount of rework to do it would have been massive and more work than it would be worth for something that would be more for looks and with minimal other practical benefit. At least in my case.
