- Feb 8, 2022
- Saint Paul, MN
No question about it, body and fender work is the most expensive part of your pride and joy. Rust is, of course, its worst enemy. It comes on slowly but surely. Once it gets started, it’s hard to stop. You can change your oil religiously, but it’s equally as important to keep the rust worm away.
There was once a time when Rangers were cheap and plentiful. But those days are gone. Yes, Ford still makes them, but their new newer versions are not at all like those old minitrucks we have come to love. Gens I and II may still be plentiful especially in the south and the west, but they are a dying breed. Let’s keep them on the road.
Wax is not just superficial. Nor is it cosmetic. Few of us want a pavement princess anyway. Wax is practical. Done right, it will last a long time. Those new “ceramics” are also easy to apply.
When it comes to ceramics, the sky is the limit. Some will last for a very long time. The kind that comes in a 1 oz bottle will do the trick but will cost a hundred bucks. Then again the truck is is not your wife’s Mercedes. It’s just a truck. Let’s get real world here. Let’s just do the basics.
Your friendly local parts store has lots of cheaper systems to choose from. You know all the usual brand names. Pick your favorite. They are all good. But they are not all the same. Once you choose a brand, stick with it. Do not mix and match. Turtle Wax is the cheapest and the easiest to apply. I put some on a year ago. It still looks good.
Here’s some things you might need:
Begin by washing. Dish detergent is okay, but just this once. It will help to strip off the remains of old waxes. Wipe down again with the 50/50 mix. Check old wax by spraying water on it. It shouldn’t bead up. It should form an even sheet instead. Use the 50/50 mix again if necessary, or just using rubbing alcohol straight.
Next deep clean, Clay bar the truck to remove stubborn contaminants like brake dust. Follow the directions. Or use spray clay bar. Let the product soak for a few minutes then wipe with a microfiber mitt, rinse, and dry. Spray clay bar also helps to remove wax.
Then buff. Put a few drops of polishing compound on the polishing pad and run the buffer back and forth with overlapping passes on a two-by-two-foot area. Wipe the compound off before it dries hard. Buffing should remove fine scratches such as swirl marks and even flatten out the paint job. Buffing will flatten the paint, make it more reflectant, allow for a deeper shine, and make the surface downright slippery.
“Wax” when finished. Follow the directions.
Maintain with an occasional detail spray after washing. A second wax is always good. Turtle Wax Flex can be used like a detailer on wet surfaces or on dry. This may sound like a lot of work, but wax repels water and dirt and reduces the need for frequent washes.
How about you? What do you do?
- A clay bar kit, OR a liquid “clay bar” in a spray bottle.
- A cheap battery powered buffer or a buff pad.
- Buffing/polishing compound (there's a number to choose from, everything from deep cuts and scratches to very mild)
- A spray bottle of detailer
- A spray bottle of water
- A spray bottle of water and rubbing alcohol in a 50/50 mix.
- Some small microfiber towels.
