ekrampitzjr
- May 28, 2021
- Virginia
- 4.0 V6
Allergy to nickel, especially on the skin, is surprisingly common. It can show up during ear and body piercing.
I’ve always preferred traditional electric coil stoves over glass tops.
Feels like the coil stoves start butting heat into the pan instantly and the glass tops take a 1/2 hour to start getting hot.
Not trying to create a bunch of work, but it could be pretty easy to convert to a propane stove if you wanted gas.
I much prefer a gas top but electric oven. I need to see if the induction stove works with cast.
Since @fastpakr posted a pic a few pages back showing one. Thoughts about cast iron on a glass cook top?
I know years ago, when glass tops were still a farily new thing, the consensus was that the two shouldn't be combined. Considering how many people like using cast iron has that changed?
Since I left Boy Scouts almost 20 years ago I haven't used cast iron much, ok almost never. I've got a few pieces, but I'll admit that I haven't looked at them in years and last time I did they were rusty. Currently have an old coil type electric stove and thinking about repalcing/upgrading appliances and would like to go with a glass cook top. I may not use the cast iron much, but I do want to retain the capability.
Recently I've had people tell me that you can use cast iron on a glass top if it was designed with a smooth bottom for that purpose. Of course I'm not going out and buying some high dollar cast iron just for that. Seeing the way some of you are refinishing your pans, I'm wondering if it would work to just take an angle grinder bottom and sand it smooth next time I'm refinishing them. If not and I go through with the glass top I'll probably pickup a portable single burner electric to use when I want to cook with the old iron.
Induction works with copper. That's how transformers work.Induction works with steel, cast iron, and a lot of stainless. It is supposed to be just as quick as gas and the stove surface stays relatively cool. So less chance of getting burned. The heat generation is in the material of the pan or pot instead of the element or burner.
This is not from personal experience but from I’ve been told by different sources.
