- Feb 8, 2022
- Saint Paul, MN
I found my frame rusty but well worth saving. That's why I bought it. This is not the case for many other 20 year old Rangers up here in the snow belt. I sand blasted/media blasted it. The blaster removed the crusty rust (and will find trouble spots). A cheap blaster cost about $80. Then I repainted it with POR 15.Thanks much for all the comments! OK I spent some time on my back yesterday trying to decide if I want to do this or not. There are definitely areas that need to be cleaned up/welded if I keep this and make it roadworthy again. Mainly body stuff and the cross members on the underside of the bed. Can new cross members be purchased somewhere? Or are those welded to the bed itself? I don't know what the technical name is for them. The bed itself has quite a bit of rust around the bed bolt holes. Would it be possible to repair that with welds if i got new cross members for the underside of the bed? Or what about buying a new bed from a junk yard?
I had one of the shackles in the rear replaced years ago this time I'll definitely replace all the rest if I do this.
The two main chassis beams that run the length of the bed and motor mounts are the areas I'm most concerned about. Have not looked close at them yet - there are some areas on the main beam where the rust is like large flakes so
I don't know how much thickness has been eaten away from the main beams. Anyone know what the factory spec is on those beam thicknesses? I could take a micrometer to the areas I'm concerned about.
UPDATE: My neighbor who does welding and does this kind of stuff all the time said on an older rusted out ranger he worked on the rear was rusted out so bad - he actually cut the frame off right up to the back of the cab, and spliced a newer frame and box to the frame under the cab. Brand new back end from the back of the cab to the rear bumper. Sounds pretty cool and radical for trucks rusted out much in the rear. My question is - Has anyone here actually done that and were the results good?
I painted the frame under the front half too. Putting it up on ramps was all it took.
The bed floor was badly rusted and showing holes. I sealed it with POR 15 and covered the holes with a homemade oak bedliner.
My friend has a Ranger with a badly rusted frame. We intend to take the bed off, sand blast it, and bolster it this summer. And yes, the worst always the back half.
I found it's easy to restore a Ranger. Cheap plentiful parts at the U Pullyard make the job worth it too, even if it is far gone. Trust me. I'm no mechanic. My friend and I have already discussed buying a third Ranger and fixing it up, just for fun.
