10k? A forged, boost ready 632ci shortblock is 6k. Heads another 3k..
Sticking with ford in this build; This is a photo from the builder before It got crated up, I'll post more photos of the engine when I get to painting the block in the spring time.
Specs:
Dart SHP 351W Based, Machined Block, 427Ci
4340 Forged Steel 4.00 Crankshaft
4340 Forged Steel H Beam Connecting Rods 6.200
With ARP 2000 Rod Bolts
Wiseco 2618 Forged Pistons (32cc dish, TFS) 4.125
Wiseco GFX Ring Package - Turbo
Clevite 77 H Main Bearings
Clevite 77 H Rod Bearings
Dart Coated Cam Bearings
Screw in Oil Galley Plugs
Fel Pro Rear Main Seal
ARP Main Studs
Freeze Plugs
Comp Cams Turbo Custom HYD Roller Billet Camshaft
ARP Cam Bolt
Cam Retainer Plate
SA Gear Billet Timing Chain w/Torrington Bearing
Fuel Pump Eccentric, if using a mechanical fuel pump
Trick Flow Twisted Wedge CNC 205 11R Cylinder Heads 66cc = 9.3 Static Compression
Morel Hyd Roller Link Bar Lifters 5323
4130 Chromemoly .080 Wall 1 Piece Formed End Pushrods
Trick Flow Roller Rocker Arms 1.6 7/16th
Fel Pro MLS 1134 Head Gaskets
ARP 1/2' Head Studs
Melling Select High Volume Oil Pump 10833
ARP Oil Pump Bolts
Moroso Oil Pump Pick up - 24532
ARP Billet Oil Pumpshaft
Fel Pro 1 Piece Oil Pan Gasket
Moroso 7qt Oil Pan - 20520
ARP Oil Pan Bolts
Timing Chain Cover
Fel Pro Timing Chain Cover Gasket
