- Feb 11, 2021
- Seattle, WA
- 3.0 V6
- My credo
- Keep your mind like an umbrella, it only works if its open... Continually learning.
If you use 4x4 on dry pavement you get wheel hop in front. Shouldn't use on dry pavement, etc.
Dana 35 is an open differential, right? So why the wheel hop, it should just act like a regular open diff.
Front and rear driveshafts are turning identical, but, rear has LSD, it's not locked, and seems like the front/rear diff's should operate independently.
So what causes the wheel hop? It's like saying the fronts have a locked diff but they don't. I'm missing something.
If you're getting wheel hop going straight, then your diffs have different gear sets. Wheel hop is normal when turning. You won't get it on gravel, but you will hear the tires slipping if your windows are down.
