sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
GMRS Radio License
TRS 25th Anniversary
- Mar 11, 2017
- Aliquippa
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3 EcoBoost
- Automatic
- Tire Size
- 265/70R17
- My credo
- Anything that can go wrong, will go wrong. Plan for it as best you can.
The newer rangers that have locking diffs from the factory. They are electric, you press a button and it locks everything up. Also you have hydraulic or pneumatic versions that are aftermarket.
I've always found that FWD cars were pretty terrible in the snow. By virtue of the engine being on top of the drive wheels, you do have more traction from the get go. However, a RWD with added weight over the rear is 40x better. Once you loose traction in a FWD car, you loose all control and you're just along for the ride. Especially in an automatic where it's harder to get the trans in neutral to let them coast and regain traction. With a RWD car, even if you loose traction on your drive wheels, you can still control the direction you are going since it's harder to get the non driven wheels to slip. You let off the gas a bit or push in the clutch and the rear wheels will just fall back into line with the front and straighten you back up.
The average person likes FWD vehicles just like they like all season tires. They are cheaper and usually will get them from point A to point B, The FWD just allows them to get by with the all seasons better. Right up until the tires lose traction and they run right into that tree or pole directly in front of them that they were trying not to hit.
