- Jan 12, 2021
- Walkerton Va 23177
- 2.9 V6
- Total Lift
- 3"
- Tire Size
- 31x10.50R15
Well they never responded anyway, typical craigslist..
The sway bar desperately needs frame extensions. As it looks the axle might get 1/4" of droop.I remember seeing this over on the BroncoCorral. @tw205 used a new brake line mount on the frame to overcome the non-existent 90 degree bend in a stainless brake line.
Well I have tracking on the lines hoping they come in before the weekend but doubtful. I’m thinking they will be too long as well and have excessive slop but who knows… being they only offer one set for 3-6” id bet a paycheck. Even the 2wd lines I ordered from Dorman that showed only 2” longer than stock had PLENTY of extra length only problem was the orientation was terrible..I am interested to see how the Duff lines work. I got the SS set from the Bronco Graveyard and I'm not overly thrilled. I haven't found a good way to keep them off the tires or springs.
I also currently don't have my front sway bar on. It will still bolt up when the truck is sitting on its wheels but will limit travel when wheelin. I was considering cutting off one of the ears off the lower bracket so I could install a pin/key to make them disconnect-able.
