- Aug 31, 2021
- Roanoke VA
- 1997 and 1999
- 4.0 V6
- Tire Size
- 31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
- My credo
- The perfect is the enemy of the good.
Shran It should fit there's about 1/2" of the nut available past the 4 bolts. Thanks for heads up.
Caleb like the rest of things (except the rad and hoses) it was just to make things new. I see there are actually 2 sensors... rather than ask a bunch of dumb questions, probably better for me to wait until I have the manuals they should tell me the answers to what they are.
In looking at it this morning I notice the tensioner sets canted relative to everything else. That means the ribbed wheel the belt rides in is canted. I have to think this is not normal and would cause excessive wear on the belt.
I was ordering the serpentine just to know I would have new one in, and Rockauto says you should replace tensioner when replacing belt because they have the same lifespan.
Shouldn't I expect that with new tensioner, it will set parallel to everything else? You can see the outside part of the tensioner itself significantly angled relative to everything else and to me that would say it's failing but wtf do I know.
Could not get good pic... let's just say it's a readily noticeable angle compared to everything else.
Don't know if I need long fork took (belt install tool). I suspect you might need it if you are -not- taking out the rad and shroud.
