sgtsandman
Aircraft Fuel Tank Diver
TRS 25th Anniversary
- Mar 11, 2017
- Aliquippa
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3 EcoBoost
- Tire Size
- 265/70R17
- My credo
- Anything that can go wrong, will go wrong. Plan for it as best you can.
Either looks okay. Window cleaning jobs in the morning. Weather might be iffy by the 29th.
If what they say about the winter being a cold and snowy one is correct, it's only going to get worse. I can clear out the driveway and the garage so the truck can be pulled into the garage. There isn't a ton of room but enough to get the work done if need be. I've had each truck in there and had enough room to get some pretty heavy maintenance done on the 1998 & 2011 with the door closed and heat going. It's all about proper positioning.
