Ford ranger 5.0 swap
South Carolina
I’m trying to figure out if there is 2wd automatic transmission that will mount up to a 2000 Ford Explorer 5.0 engine to use in a ford ranger swap or can I just use the awd trans that comes with it and take out the shaft running to the front. Need answers asap
Welcome to TRS :)
You can use AWD power train in a 2WD but it won't Hold in Park on a hill, which can be an issue, lol
AWD is different that 4WD, AWD uses a fluid coupling in transfer case, without front driveshaft and wheels to hold it it can slip
4WD is direct drive, but shouldn't be used on dry pavement like AWD can
The 4R70W automatic transmission came in 2WD or 4WD/AWD versions, and on the 5.0l OHV engines
Not all V8 Explorers/Mountaineers were AWD/4WD, a lot were 2WD
So just trade, or sell and buy, a 2WD version
Your 4R70W with transfer case is worth something to some one
Plug and play for 5.0l Explorer computer, 2WD or 4WD is not part of engine computers software, its a separate control system
Bookmark this page: https://www.therangerstation.com/tech/
Look in the engine section or Conversion section for V8 swap articles
Thank you for this info. So as long as I use my parking brake Will it be fine with it mounting up to my existing tranny mounts. Like will that transmission fit and work with me just letting the transfer case hang there without a shaft going to the front. And is there anything else that the trans for that went into besides the explorer like a f150 or something.
Considering I’ve bought a running driving AWD Explorer missing the front shaft and one (oddly) missing the rear shaft, I’m gonna say the AWD case doesn’t really care.
Dose that mean I can use the 2wd 4r70w from a f150. will it bolt up and work with the 5.0 explorer engine
That, I do not know for sure. I would think it should if the bellhousing is a match though. May need a different driveshaft or way to adapt it, not really sure on that one. I’m doing a straight swap, Explorer 5.0, auto, AWD into a 4x4 Ranger so I’m using the AWD case and bolting up the driveshafts
F-series would have to have had a 5.0l OHV engine, so 1993-1996 with 4R70W
1997 to 2001 only the Explorer and Mountaineer used the 5.0l OHV
Would a 4.2 4R70W not work?
Ok I am not new to the ranger seen but am new to the v8 swap seen taking a 2.8 an manual 4 speed out an want to put my 302 with a aod in what is the easiest way about going to that do I buy the swap mounts or do I use the early 90s mustang convertible mounts
hi benny and welcome.
every swap is unique to the builder and from what i have read, no 2 builds are the same. what is easy for one person could be extremely painful to another. my suggestion is to read all the posts you can find and make notes. believe it or not, on my 83 build I am still using the 83 motor mounts that where with the 2.8. (modified, but worked) as it was a cab off frame build. it was the mounting plates that were modified to fit properly.
cheers
Benny, Angie is spot on. My 88 is 4wd amd used the James Duff heavy duty mounts for HP purposes (made me feel better about it I guess)...BUT...the spot i had my engine builder weld a bung into the oil pan (the Ford "Performance" dual sump pan comes with a dipstick but no dipstick hole lol) there is no provision for a dipstick because the Duff mounts are blocking the hole. I also had to grind material off of the mounts as im running an aftermarket Dart block, so idk if that made a difference as well...."Duff" headers were a royal PITA to install....and they leak, so need to address that now. I will tell you that the convertible mounts would be MUUUUUUCH easier to install (as would making your own mounting plates)...i used my trans to locate the engine in the proper location on the crossmember....it was still a ROYAL pita to finally get right. Aftermarket radiator that fits inside of the core support, then had to try MANY different combinations of flexible hoses and clamps to FINALLY make it work. With a 2" body lift I had to make no modifications to the firewall seam...the list goes on and on and on and the charges to the checking account are almost done. I would NEVER, EVER do this again....was a frame off restoration (88 Hi-Rider on 35s now, 8.8 rear built to hell, dana 35 front, built c4)...was my first vehicle when i was 18, im 42 now and has been in the garage the last 19 years...never had the funds to do it back in the day....do TONS of research, the guys here are EXTREMELY helpful and go out of their way to take the time out of their day to help as much as they can. Their knowledge is indispensable.....for what its worth we had a 98 Explorer AWD 5.0....over 250k miles when we did the cash for clunkers thing back in the day (we were poor and needed a new vehicle)...that 4R70W shifted like new. I always LOVED how that thing shifted.
Mustangs with 3.8 are excellent source of 4R70W 2wd transmissions, that's where I got mine from.
Upcoming TRS Events
