1993 Vacuum diagram 4.0 ohv v6
firemanst13
Forum Member
Firefighter
I am in desperate need of a diagram that a dummy can read. I have a 1993 Ford Ranger 2door extended cab xlt 4.0l v6 5 speed manual. I have replaced the engine with a long block from Jegs and I think I have the vacuum lines corret but it does not always run good. I cant get the 900 RPM to stay, and sometimes it has good power and some very lacking. I have new fuel injectors for it just have not put them in yet, just want to make sure I have all the vacuum lines ran correctly first. Thank you ahead of time
Here's one
There aren't very many vacuum lines on the 4.0. Which ones are you having trouble with?
I have no idea, it is just running rough, bad vibration and loss of power. I think I finally figured out the vacuum lines, I had one under the fuel return that was not hooked up and there was one on the idle control that wasn't hooked up. I hooked those two up, but it didn't have any change in how it is running. Here is everything I have tried, replaced with long block, new plugs, fuel pump and sending unit, MAF, idle control, new fuel injectors, cleaned the throttle body. All I can think of now. When I first started after the build, it ran like a sewing machine, smooth, plenty of power, but it has been going downhill since and getting worse. I also drained the gas tank and new fuel filter and clutch and all that stuff you would change when you have it as far apart as I had mine. I need help, nothing I do really makes it worse and for sure not better. I did try starting it last night with full throttle which I was told can check your fuel injectors from leaking and it did not even act like it wanted to start. I am a little confused on the Manifold fitting and then to engine. I have one that goes to my air breather box to the VDB, but I don't see it on the drawing
Most likely. I'm surprised to see vacuum for the heat/AC controls prior to 93 though. I just kinda assumed 89-92 used the same controls as 88 and earlier. No vacuum on the early ones. It's all cables.
