A4LD_Nghtme
So I've officially finished rebuilding my passenger drum after replacing the siezed parking brake cable and so I began to bleed the brakes.
I bled the passenger wheel cylinder first and was able to get brake fluid to bleed through it. Upon cracking the bleed valve on the driver side wheel cylinder and attempting to bleed I got absolutely zero fluid pushed through at all.
Does anyone know why this may be happening? Is there a proportioning valve of sorts on the Bronco IIs that may possibly be my issue? Lines aren't leaking, kinked or broken
