what kind of spark plugs should i use for a 2.9L v6 motor
which spark plugs are the absolute best for a 2.9l v6 motor
  • copper
    Votes: 3 50.0%
  • platinum
    Votes: 0 0.0%
  • double platinum
    Votes: 0 0.0%
  • iridium
    Votes: 1 16.7%
  • double iridium?
    Votes: 1 16.7%
  • other..
    Votes: 1 16.7%
  • Total voters
    6
stamina
Forum Member
Wilmington, NC
4” suspension
265/75/r16
built her in a storage unit
i honestly just want to know which plugs are the absolute best ones that i could possibly use for this old motor, it’s a 1990 2.9l auto 4wd. not afraid to shell out a little extra just want to know which ones are the best of the best for this lil v6💪🏼💯
Single platinum or iridium tip will last longer
Motorcraft AWSF-42C was spec and tend to work best
Gap at 0.044"
Motocraft AWSF42P. Platinum version of original plug, can be found ridiculously cheap on eBay:
Just run the motorcraft copper cores. The ignition on these trucks arent "hot" enough to make any good use of anything fancier then that.
You can run quadruple platnium 4 electrode magic dust whatever whatever, wont hurt nothing but your wallet.
LMFAOO had a great laugh soon as i woke up😭😭thanks for your knowledge bro
The advantage to platinum or iridium is in longevity. If they're not hard to get to, then copper is just fine. If the job is a pain and you'd rather not repeat it for the rest of the truck's life, consider spending a few extra dollars.
Expensive ones. I have more trouble trying to save money with plugs then I care to admit to.
motor craft SP (486 or 419). run these for a long time.
