- Jul 31, 2021
- NW Florida
- 2.3 (4 Cylinder)
- Total Drop
- 1.5” till I get these springs replaced
- Tire Size
- 225-70-R14
I measured as best as I could with my hand and found that the front left sags about 1.5” lower than the right. I assume the coil spring is the issue, but I want to see what all I should check to make sure this isn’t an actual problem. I’m replacing a radius arm (shock mount sheared off) and could replace the springs while I’m at it. The missing shock is on the sagging side, but it doesn’t seem like that would cause it to be so lop-sided tho.
1994 single cab
1994 single cab
