- Feb 28, 2001
- Dayton Oregon
- 2.3 (4 Cylinder)
- Total Lift
- 6
- Tire Size
- 35"
Yes, that's the factory PCV, they haven't been made of bakalite in a while
Yes, that's the factory PCV, they haven't been made of bakalite in a while![]()
The PCV is connected to a vacuum line. That one line that connects to it goes to the intake manifold. Intake vacuum sucks in the crankcase fumes through that line. When you shake that PCV, it should rattle. That's what controls it. If it doesn't rattle, it's no good.
I think I’ve about figured out how this system works. I had knew generally before but not the details. I thought it was computer controlled, but it’s basically a check valve/ flow metering valve. I bet they started with just a hose but turned out to need a varying flow rate
They started out with a hose hanging under the car, used the draft from the car moving instead of the engine vacuum
I’ve read about that. Would i be correct if I said that was before it was an emissions thing? If you don’t have a vacuum on the case, water gets in the oil and it gets frothy?
Or breathers on the valve covers. That's what I always did anyway. Toss the hose and replace it with one of those small filtered breathers. There are some Lightning guys who have deleted the PCV system and replaced it with breathers. Myself, I believe it's beneficial to have that cold air going through the block from one side to the other.
PCV and forced induction can be a pain in the rear, positive pressure to the vacuum line doesn't work very well...
Breather filters are fine and all, but the hose between the breather and the intake tube behind the air filter is basically the same... so if it ain't broke, don't fix it...
The PCV system on the Lightning causes a lot of oil in the intake above the blower. The blower and the intercooler end up being caked with oil from the PCV. That's why some guys delete it. Others like myself install an oil separator in the line between the PCV valve and the plenum to capture that oil. I removed the blower and intercooler from mine in 2019, cleaned up the intercooler, which I could not see through from all the oil in it. Installed a Magnum Powers blower and an oil separator. Been good ever since. Just have to remember to put a rattle can lid under the thing and crack the valve every thousand miles or so.
