Hi all!
Like most I’m banging my head over this issue. Have replaced egr valve, DPFE, EGR tube and the dpfe hoses with all motocraft parts, as well as the EVR (vac solenoid) on my 97 ranger.
p1401 insufficient egr flow still pops up! I run forscan and the dpfe voltage hovers at .98 or .99 volts at idle. I cycle the egr to 100% and I get vacuum on the line going to egr valve, when plugged into the egr valve and when activated, idle gets noticably rougher but not to the point where the engine feels like its going to stall. When running and driving normally dpfe voltage goes between 1.26 and 1.5 volts.
the ONLY thing I havent thoroughly checked out is the egr port on the engine for carbon. The old egr valve was not totally clogged up and the tube seemed clear so I dodnt give much thought to it.
Does anyone have any suggestions on what else to check to make this CEL go away permanently. Its driving me bonkers!
thanks,
Ron
thanks,
Ron
