lil_Blue_Ford
Cut & Weld
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Total Drop
- 4”
So my red 92 now has a one-piece rear driveshaft...
one broken socket. One new driveshaft removal tool damaged. Few beers (lubrication). Had a disagreement with the rivets, ground the heads off for the carrier bearing mount attached to the crossmember and couldn’t get them to beat out. Of course, there’s not much room to swing under there without a lift. Really would have liked to have gone at them with the torch but with the gas tank right there...I went for the grinder. Looks like without that bracket there is plenty of clearance to the crossmember so I should be good.
Turns out the shaft I took out had a bad U-joint in addition to the carrier bearing being worn. Now the truck sounds and feels different. Thinking it’s probably the mud tires at this point but might take a few days to get used to the different sound so I can work out what I’m hearing.
