- Sep 22, 2007
- Michigan
- 2.9 V6
- My credo
- A legend to the old man, a hero to the child...
Listen to @RonD for the finer points of the ECM. Im far from an EFI guru. My speciality has a choke and idle screws lol.What do you make of the eec showing a huge decrease in voltage st pin 22 between KOEO and KOER?
I’ve done what you said many times, with two sets of injectors (one remaned and one cleaned and checked for function and spray pattern), hoping for a different result each time. Nothing. Exact same symptoms. I suspect that my fpr has failed internally as even priming many times won’t get my pressure up to 42 psi. That is supposed to be the preset spring tension in the fpr, yes?
There are two things I haven’t done yet. One is to throw on an old regulator with the return line capped to see if it will then hold after priming. That isolates the rail and high pressure check valve. The other is to hard line the fuel pumps with 12v to see if the changes it’s behavior. But again it seems I have two issues here. Unless the readings I’m getting from the computer check out?
If the FPR has failed there will be fuel in the vacuum line running between it and the manifold
