2.3L ('83-'97) Harmonic Balancer Bolt
So Lima and duratec must be the same them. Im sure it can be a lil shorter..
I somehow doubt they are the same. Dunno never pulled mine off but the system in which they are attached is insanely different. Lima is keyed and not even pressed, it "shouldn't" require a puller to remove. The duratec bolt might even be torque to yield since it requires a very specific torque value to work (it's not keyed, and the balancer holds the crank pulley on which is also not keyed) the duratec system is friction only and if it let's loose your buying a new engine. Even loosening the balancer on a duratec before locking the camshafts will result in engine damage.
I could be completely wrong, but just based on how different the engines are I'd think the duratec bolt is larger, finer, or TTY. :dunno:
The bolt in question:
I'd pull mine off to compare if you gave me the 400 dollars in tools to do it. :icon_rofl:
The newer jeeps dont have a key way and the bolt is reusable..... 🤷‍♂️ dont know
The 4.0L is TTY.
I'm not sure about ours...
Doesn't seem to be. Whats weird is you would think with all the dirt track guys, there wound be an arp bolt.
Dirt track requires a distributor ignition, aka old old block. (Pre 86?)
Dunno if they are different but I'd think the earlier ones with no crank trigger had a different bolt simply cause, science?
The crankshaft is the same all around I think, the '85 crank bolt is like 1/2" longer than the '89 style, probably changed in '86 with the small journal crankshafts.
FWIW, the distributor hole went away in '96 with the oil pump behind the aux pulley, the blocks had the distributor hole but a distributor wouldn't fit on the engine because of the lower intake manifold, change the cylinder head and you can now fit a distributor...
1996 Ranger 2.3l.
Bent my harmonic balancer bolt while trying to remove the balancer with a puller.
Trying to find a replacement online and no luck.
Any suggestions on a new one, whether OEM, ARP, etc? Would rather avoid a hardware store special.
I know this is an older post but I just encountered this issue. The harmonic balancer is available but the bolt is not.
After a lot of research I found a mopar knuckle to hub bolt from a ram 3500 is the same bolt with a jis head. Same 14x1 50x55mm at 10.9 hardness. Use the old washer, thread length is the same. Mopar part number is a 5086661AA and the Dorman cross reference is 926-171.
Readily available alternative.
