- Feb 11, 2019
- N/A na
$3.35 just need the washer.
So Lima and duratec must be the same them. Im sure it can be a lil shorter..
The newer jeeps dont have a key way and the bolt is reusable.....I somehow doubt they are the same. Dunno never pulled mine off but the system in which they are attached is insanely different. Lima is keyed and not even pressed, it "shouldn't" require a puller to remove. The duratec bolt might even be torque to yield since it requires a very specific torque value to work (it's not keyed, and the balancer holds the crank pulley on which is also not keyed) the duratec system is friction only and if it let's loose your buying a new engine. Even loosening the balancer on a duratec before locking the camshafts will result in engine damage.
I could be completely wrong, but just based on how different the engines are I'd think the duratec bolt is larger, finer, or TTY.![]()
The newer jeeps dont have a key way and the bolt is reusable.....dont know
Doesn't seem to be. Whats weird is you would think with all the dirt track guys, there wound be an arp bolt.
I know this is an older post but I just encountered this issue. The harmonic balancer is available but the bolt is not.1996 Ranger 2.3l.
Bent my harmonic balancer bolt while trying to remove the balancer with a puller.
Trying to find a replacement online and no luck.
Any suggestions on a new one, whether OEM, ARP, etc? Would rather avoid a hardware store special.
