- Nov 7, 2019
- Age
- 30
- Georgia
- 2.8 V6
- Total Lift
- However much it goes up when I get my fat ass out.
- Total Drop
- How much it goes down when my fat ass gets in.
- Tire Size
- Dry rot and old
I am glad you got your meter out. I think you are getting it. Think of the wires as water pipes with water flowing through them. Think of the battery as a container of water with a pump.
Your meter is measuring the water pressure (voltage) at different points in the system. You are just looking for the point where you are losing pressure (voltage).
So when you try to crank it, you are demanding a lot of water pressure. You are not getting it. So you just need to put your meter on the negative post of the battery, and start probing the wires (water pipes) starting at the battery. Problem is, unless you have it rigged up you need help to demand pressure from the system to be able to check it properly. You need someone in there turning the key to start while you are holding the meter on the battery and other places.
So if you were able to put your meter right on the battery posts, and tried to crank it and the voltage went to 6 volts after being on the charger all night, I agree your battery is no good.
Yeah, The battery is wired all up the same as it was yesterday. I haven't changed anything. I just yanked the battery and popped it on the charger. Would you happen to know a good place that has the best price for a battery? Since I've got an interstate battery. I didn't know if they are good or if a specific auto parts store sells batteries. NOTE: Im not brand loyal unless Ive got a coupon lol. I go where the price is right.
I cant wait until I get this beast running. That just means once shes running. The sooner I can get around to rebuilding the motor and restoring it. I wanna get her look new under the hood and nice ish inside the cab and like a beat up POS on the outside.
