franklin2
You mean 24 valve heads? All 2.9's had at least 12 valves.If someone were inclined to look for the 12 valve heads, what vehicle might they find some used ones on? I have a 2.9L that I would love to experiment with.
The 2.9 ohv in ranger and rbv, merkur, capri, granada, etc is a 12 valveIf someone were inclined to look for the 12 valve heads, what vehicle might they find some used ones on? I have a 2.9L that I would love to experiment with.
Thanks. I appreciate the replies.
Being new to this, what could I bolt on or replace on the 2.9 to boost the horsepower? Not trying to create a street rod, just move faster when I press the gas.
Please don't interpret this as agression or me being a d*ck, but you are dead wrong.Not much you can do, the stock computer is going to hinder you with anything you do.
Thanks gaz for the info and the offer but I’m not at that point yet. I’ll keep your reply and consider you a source when I get there.89 or newer heads are the newer casting. I have an extra rebuilt set if your interested.
See the first post of my build thread, and look under modifications. Every single mod is discussed in a post in the thread, or another post on the forum in the FI or 2.9 section.
1988 Ranger Restoration - Keeping a Promise
Ok, so just a forewarning, this post is going to be heavily edited, re-written, and changed throughout its construction. This is being written as a post to document the restoration of a truck that was a terrible candidate for restoration, and to offer explanation to others that read my posts...www.therangerstation.com
Kunz's Korner in the tech section is a good starting point. It's how I got my start.
Electric fan, porting your intakes, electronic power steering conversion, headers, etc. will let you pick up ponies without too much trouble.
3g alternator swap will be necessary to run the electric stuff. Always get the highest amp one you can fit, the bigger the alternator, the less stress on the engine when under load.
94/95 3.8 windstar was my alternator and harness donor. Best $50 you can spend on a first gen(30 for junkyard alternator, 20 for a chevy bracket and bolts).
Also, strongly recommend upgrading as many bushings as possible to polyurethane, and get a hold of B2 front and rear sway bars. Will let you control the truck with greater precision, which means easier to put power to the road.
Line by line:Do Members call you Petro for short?
Thanks for the great advice and sharing the link to your 1st Ranger build. I have always respected a man that understands his limitations. After viewing your build, I can honestly say that I can never see my level of automotive mechanical expertise matching yours.
That being said, be prepared to be continually tapped on the shoulder for advice. My local truck pick and pay yard just sent me an email that a 85 B2 just landed. I’m hoping the sway bars are still on there tomorrow.
Is the harness from the donor Windstar difficult to install? Where could I find technical direction/guidance for that harness swap? Would it matter if I made the alternator upgrade before the other electrical upgrades?
In your thread, you mentioned that the JBA headers were ‘reversed’. What did you mean by that? Headers and a 2.5” exhaust are a short term upgrade I’m considering now.
Do you suggest putting a 4.0 radiator in along with the electric fan? I’ve read that upsizing the rad will help the trans.
Aftermarket cold air intake or modify the stock box to allow more air in and install a K&N filter?
I replaced the ABS unit under the master cylinder/near the steering column but the light on the dash is still on. New brake lines, wheel cylinders, fluid, pads, etc. Brakes work fine. The pesky light is still on.
I won’t monopolize your time but there is more to come. Thanks again for your input.
Not sure. There's others here that have driven it and laughed their asses off over what it was capable of. Amazed me that the cam was dead. But yes, megasquirt was all the difference in the world.Do you think you picked more than 20hp from all those mods? Of course I know you don't really know, I am sure you picked up some horsepower but it's not going to be significant. Isn't that the reason you got rid of the stock computer system?
Your only hope with a speed density eeciv is to maximize your volumetric efficiency, reduce parasites, and cheat the system where you can with resistors, etc. Gazs build is a damn fine example of just that.
Megasquirt to the letter. I have a DIYPNP v.1.5, so it was a matter of connecting jumpers to the header board, and plugging it into the factory 60 pin connector. So installation for me was literally a 10mm bolt. Annnnnnd.... not much else.I have mentioned before the stock 2.9 I had in my ranger had good power. I can see why people would want to modify it, sort of like the old 5.0 engines, which ran pretty good stock, so lets see how much more we can get out of it. But like Ford cylinder heads,, the EECIV system seems perfectly fine for a stock engine, but is hard to modify it to get real power.
You left a link in one of your posts to your megasquirt stuff, but it was only your fueling and timing charts. I thought maybe you had a series of posts somewhere on the actual installation and wiring/mounting of the megasquirt unit. I want something I can actually hook a laptop to and troubleshoot. Something were I can go in and set the idle speed, not being locked in to what Ford programmed in.
I got lucky and found an unfinished one on eBay. IIRC, they discontinued that exact one, but the MSExtra forums have tons of info on how to get around it.
There is a tuning shop out by Philly that sells jumper harnesses for the 60 pin connectors as well. Makes a MicroSquirt plug-and-play. The only difference between the Microsquirt and the DIYPNP v.1.5 is the case, header to connect to the harness, and a few in/out relays. Otherwise, a micosquirt readily fits in the floorwell, and can even be made to fit into a gutted factory EEC-IV case. Couple jumper wires and a soldering iron, and you got yourself a DIYPNP fo' the cost of a JY EEC.
The MS version of TunerStudio is free to download and mess with. Idle speed is Level 0 stuff for that suite.... Not even funny the levels of control that it gives you.
As far as diagnostics are concerned, it is unparalleled IMO. Others will disagree. That's ok. I handle Data Logs all day, so the MS format is natural to me. OBDII is not.
