- Sep 22, 2007
- Michigan
- 2.9 V6
- My credo
- A legend to the old man, a hero to the child...
FWIW a 2.3 ECM isnt going to run a 2.9
Can you get me a photo of the tags on your ecm? 10% chance I have one here that I can exchange for yours.You are RIGHT, bruddah!! I sure hated to see this one bite the dust when I have been jump starting off of it for the last 20 years. And yep, the cables were on the right posts.Just one of those things I reckon.
10-4, thanks PJunkie.Can you get me a photo of the tags on your ecm? 10% chance I have one here that I can exchange for yours.
RustyFWIW a 2.3 ECM isnt going to run a 2.9
Thanks Ron, I'll do that next. If that doesn't cure the problem, I have a bad(also a good one) EEC out of my '88 that I can pull apart and study the PCB on to see what may have gone bad in the '87 EEC. This can't be rocket surgery. Would the good EEC out of the 2.3 '88 not run the 2.9 '87, as rusty suggests? BTW, the pic is in the original post from Wednesday.Good work
I would unplug the computers connector and check inside for corrosion, also check ground wires around the computer, make sure they are tight
Also do as PJ412 said and get him a picture of computer label
pin 22 on the computer should be a GROUND on boot up and then no ground until engine starts, then its a ground again
So ground for computer is important, and good wire connection
That's what turns on the FP Relay
You can operate vehicle with jumper on the OBD1 connector in place, yes there is a safety concern because computer would shut off FP relay when engine stalled in an accident, but really up to you
Its not harmful to the electronics just a possible fire hazard
I jumped the test plug to ground and both relays clicked, pump came on, engine started and ran like it always did.
Correctomundo!! I plugged it in to see if the fuel pump relay and pump buzzed up, it did!! Yay. So of course, I had to try it. It fired up, but it was running rough like the timing was way off, so I turned it off after it ran a second like that. Fuel pump worked with it though, so that tells me it was the factory EEC that was bad. But we already knew that after the previous tests I did, plus the pulled out pin in the bulkhead connection point on the puter.FWIW a 2.3 ECM isnt going to run a 2.9
I'm sure it's all good on that side of the connection since the '88 EEC would turn the fuel pump on. I was more or less wanting to find out which pin that is that pulled out of the computer. I'll look at the pin out and see if I can tell what pin it is. Thanks again.pin numbers here: http://www.auto-diagnostics.info/ford_eec_iv
Remove jumper from OBD1 connector for this test
With connector unplugged when you turn key on you should have 12volts in the hole for pin 22, that would mean wire is OK
Well **** that ain't good.Ok, this is what I got when I pulled the plug in connector out of the puter box. Where do I find a pin out for this computer? I see a bit of green corrosion around the base of that pin that came out of the bulkhead connector.
