I was reading in the "How to Build and Modify Ford V6 Engines" and he said there is one oil gallery that feeds the rocker shaft and all the components under the valve cover.
Ok, that makes sense. I wonder why it is then that the middle cylinder is having such an issue. The ticking is loud. Too loud. And gets worse the longer I drive.
I don't understand why it looks so crusty and rusted? Where did the water or moisture come from to create the rust? Is the water causing the sludge build-up with the oil also?
From what I understand, oil is fed into the rocker shaft through the center bolt, and then Travels to each end.. from the shaft, the oil travels through the front hole that you can see on the rocker arms, then travels down each rocker arm and onto the valves. I believe the corrosion is clogging these holes on the center rocker arms.I dunno, the other two cylinders look well oiled with no corrosion. Does someone have an oil flow diagram for this engine? How do the outter rockers get oil and the center two not?
Does it require clearance to allow oil to get out? I know I've seen that on other engines where it squirted out oil when the pushrods had no force on them at th base circle of the cam.
I'd probably pull that rocker assembly off and clean up the parts - the center two at least, then readjust and do a compression check. If it had no clearance it could have a burned exhaust valve. Looking again it does seem to have oil, it's just ugly.From what I understand, oil is fed into the rocker shaft through the center bolt, and then Travels to each end.. from the shaft, the oil travels through the front hole that you can see on the rocker arms, then travels down each rocker arm and onto the valves. I believe the corrosion is clogging these holes on the center rocker arms.
There is corrosion because the bronco sat stagnant for 14 years with alot the vacuum/ breather lines unplugged. There is no water in the oil
Can you use a piece of tubing to tell where it's coming from at all?
