thanks for joining In. What I really don’t understand is why my bronco idles normally with the “idle solenoid” completely removed and unplugged. With this solenoid completely
Removed and unplugged, the throttle still does not make contact with the stopper. I know in the pictures I posted the solenoid is touching the throttle.. and it’s giving everyone the idea that this is the reason the throttle is not closing all the way.. that’s not the case.
I understand that the Duraspark conversion requires the removal of some emissions equipment. I live in an area in California where SMOG is required and is very strict. If anyone knows a way to do the conversion and keep all the emissions equipment, please let me know.
If the engine idles normally with the butterflies completely shut inside the carb, then the engine is getting air from somewhere else. Or as some of the other guys were saying, if the butterflies were removed, they may not be seated correctly in the carb and are not sealing off very well. I hope the butterflies where not removed, that is a real can of worms when that is done, and then the screws should be re-staked to prevent them from loosening and falling into the engine.
I would say your truck is just like so many others. The 2.8 and 2.9 were decent little engines, but all of them came out with this computerized carb system, and when something goes wrong they are so difficult to diagnose and repair. Converting them to something more conventional brings them back to life instead of clogging up everyone's back yards.
I don't know how your California inspection stations are. Here in Va, it depends on the person running the station. You have ones that are lax, and others that are strict. Also, when you do the duraspark II swap, you do not have to remove any of the smog equipment. You can leave the air pump hooked up, and all the other lines and stuff hooked up. It just will not work. I did the swap and are still using my stock carb and it works fine. These old things did not have a check engine light, so who is to know that it is not working. I dare to say right now that part of the problems you are having, is because your system is not working. The engine still runs, but I bet you have so many error codes the computer is hardly working at all, thus why the engine under performs.
