- Jun 13, 2016
- Connecticut
- 2.9 V6
- Total Lift
- 6
Alright, guys, I need your collective ford knowledge for the little predicament I'm in. I'm on my second 2.9 rebuild and I'm slowly learning from my mistakes from the first time I tried this. I recently purchased an 89 block from a pick and pull yard, the engine has roughly 140k on it, in decent shape. I ran a leak down test and got results leading me to replace my piston rings. I replaced the rings, honed and deglazed my cylinders and replaced every engine gasket top to bottom, new fuel injectors, sensors, etc, etc. what I want to know is the proper break-in procedure once I get the engine in the truck. I've heard everything from run it at full tilt for 20 or so minutes to baby the engine for the first thousand miles. I know I need to run high zinc break-in oil and change it after 500 miles but the exact process for successfully breaking in the rings eludes me...Haynes manual is less than useless for this. The only new internal parts are the rings and gaskets so 99% of the engine was left alone I just don't want to do something wrong and have to redo all this work again. And before you say it, I should have done a 5.0 swap and saved myself the stress of messing with the 2.9 but what can I say, I'm stubborn.
