Tacked a couple pieces of 2x2×.188 onto the frame will hang the mounts off the piece of 2x3x.250 that's across the front. I have decided I want to run shackle at rear as it seems to be the preferred from people I've talked too for ride quality.
When setting up caster fo I have to rotate forwards or back wards a degree one way or the other to deal with spring compression with weight on it? I need to get this front axle done so I can get into the rear its easy get my head around. This front axle is making me frustrated
Sent from my SM-G930W8 using Tapatalk
