Need Urgent help 2.9L died turns over wont start
88 XLT Ranger
Pollock Pines Ca
Need quick help
My 1988 Ranger 2.9l I started it up to warm it up it was running fine on its own for 20 minuts than it just died or stalled. I went to start it back up it just turns over wont start back up. I checked the fuel pressure at the rail tuned the key on pushed the nipple deal fuel sprayed out turned key off did it again fuel spayed out. I did change the computer a year and a half ago to a rebuilt one. The dist ignition sensor is a Motorcraft only 2 years old. When I crank the engine over the check engine light comes on. I never had this issue before I did notice a few times as its running it acts like its going to stall but comes back in RPM's quick
I took the cover off the computer the board looks ugly lots of pealing of clear sealer looking stuff. I seen nothing burnt or anything leaking. Its snowing here need to find the issue quick. Any help is very much appreciated
Start simple, spray starting fluid in the throttle body and see if it attempts to start. If so you can norrow it down to a fuel delivery issue. If not its a spark issue.
The cruddy computer sounds suspicious either way....
Thank you Dirtman
I will give that a try in the morning the computer one year warrenty ran out just four months ago. Its a Corman $102.99 at OReilly its the only place to get one. The board was dark looking peeling clear plastic coating stuff one of the round risitor looking things was rusty on one side at the back of the computer. The screws where so tight had a hell of a time getting it apart
Doesn't sound good but you really should pull the codes before you pull the board
I did the code scan Denisefwd93
I get codes 21,24,21,24,111,11
21 - engine coolant temp
24 - air charge temp
11 - system pass
111 - system pass
You think its the computer? I did change the coil I had a spair still wont start
I did the starting spray it woulden't try to fire up. I did the code scan results on the other post
Well you are not getting spark for some reason. Absolutely could be the computer given your description of its condition. Ect sensor and air temp sensor should not cause a no spark condition.
I will order one its from the same company hope its better I can't find one anywhere els I hope that will work
One of these is very handy to have in the toolbox, and very cheap.
https://www.lislecorp.com/specialty-tools/spark-tester
GB :)
2.9 engine infamous for bad ignition modules or whatever it's called?
When you say that you changed the "dist ignition sensor", are you talking about the pickup coil inside the distributor, or the ignition module on the outside of the distributor? If either one was bad you wouldn't get any spark.
Hopefully it's not the pickup coil, which would require removing and dismantling the distributor (or swapping it out with another distributor).
TFI module, Hall effects senson
Thank you all
Its was the TFI Module:icon_thumby:
I appreciate all the great help so very much this was a Motorcraft only 2 years old. I put my friends he bought from Ford on it runs great. I better get another for a backup. I did change the computer as well before but still nothing changed the TFI we got ignition
