Torsion bar vs ttb travel
albertb
5+ Year Member
EMT / Paramedic
Firefighter
USA
I'm looking to buy my second ranger (my first was a 07 2wd long bed). I want a 4x4 and my budget is $3000 for the truck so I'm mostly looking at 93-02ish. I was wondering what the stock wheel travel is for the ttb vs the torsion bar. Ive heard the ttb is about 8 inches and the tbars get about 5-6 inches. Are those numbers accurate?
I don't know if those numbers are correct, but I do know that stock for stock TTB will give much better downward flex.
In fact, shocks and sway bars are about the only thing that limit downward flex on a TTB. Well, and radius arms.
Yeah, if wanting suspension travel, stick with TTB, ditch the front sway bar and maybe add somewhat longer shocks and you're golden...
I have about $1000 to spend on suspension. What lift kit should I go with? Ive been looking at the tuff country 4 inch is that one decent for travel?
I think I would get 4x4junkie's opinions on the matter.
He has so much downward travel that he has had to build a setup to limit it.
The 1983-1997 Ford Ranger TTB front suspension will give you more travel than the 1998-2011 Ford Ranger SLA.
My Skyjacker 6-inch lift with extended radius arms had so much travel, that I had to use a hose clamp at the top of the coil spring to keep it from popping out of the coil bucket when I flexed the suspension.
The only suspension kits I would recommend for a true offroader looking for wheel travel would be:
Skyjacker 6-inch Class II with extended radius arms
James Duff 5-6 Inch Stage 3 with extended radius arms
These kits are around $2,000. You're not going to get a suspension setup with a lot of wheel travel for less, unless you break out the welder and fabricate your own.
Mainly make sure you get a kit without a "drop plate" for the drivers side beam pivot but instead comes with a new bracket all together. You want to get a drop pitman arm for the steering, get the big expensive one even on a 4" lift I believe, it helps a LOT.
Honestly I pieced together my lift off of craigslist, skyjacker coils I believe, around 6" lift, radius arm drop bracket, replaced both pivot brackets no drop plate, stock radius arms and I still lost a coil at one point on downtravel in the dunes, as Jim did I have a hose clamp on both coils now, as well as a J clamp but the hose clamps are still there :). I had $500 in the used lift kit, $200 in the pitman arm, $50 in new radius arm bushings, $75/pair of shocks from Jim's store, I think $25 a piece in new high angle caster bushings and that's about it.
Of course extended radius arms are on my short list, have had the parts for 5 years...
I'll probably save up for the skyjacker. Just to clarify the suspension "systems" are the class 2 youre talking about, not the "lift kits"?
Those are lift kits. You can order them with different options. But they are engineered to lift your vehicle and improve off-road capabilities. I used the complete Skyjacker 6" system/kit. That included brackets, longer shocks, leaf springs, longer radius arms, nuts and bolts, etc. It's very well designed.
This message composed solely of recycled electrons. Go green!
If you want a lot of travel with a ttb you'll need longer coils, shocks, radius arms, drop brackets for the axle beams and most importantly, a good steering setup.
The 6" Skyjacker kit that everyone has been talking about has all of that, though it'll probably come with a Pitman arm that isn't quite long enough. (FA400 vs FA600).
You can also piece together your own kit like many of us have done, which is what I would recommend. Skyjacker 6" coils, Skyjacker drop brackets, make your own radius arms, F-250 shock towers and build a swing style or custom K-link steering setup and you'll be able to get anywhere from 12-18" of travel, limited by shock choice and placement.
I used the pitman arm that can with the kit. But combined that with the prerunner steering setup from Superlift. That combination seems to be working well for me. I forgot to mention the longer could that came in the kit.
Did you need to drop the super runner kit down at all to match the FA400 arm? :icon_welder:
I know the FA600 is too long to fit with an unmodified super runner kit.
