Featured Build Threads
Right now I have a little lincoln 100a 110v flux core welder, and learning on it has been a huge pain. It just doesnt have the juice, and after trying out a friends 220v i decided to take the plunge and get a cheapo 200amp+ 220V welder. I know it'll be half junk, but decided to try out the vevor 250amp. Was able to snag it right at $200, and for how little i'll use it I feel pretty comfortable with the decision. Will be here tomorrow and I'm looking forward to getting it set up
You'll have to let us know how you like the welder. I have fondled a few cheap ones like that and the stinger & leads always seem to be too short and very cheaply made. The digital screens make me nervous too, how long till that dies? I don't hear people bitching about their Amazon welders dying left & right though so maybe they are just fine!
I bought one of the Titanium 125 flux core welders recently for $60 at the pawn shop, that little fella actually works very well. I was hoping to be able to run it off my 3200 watt generator but it trips the breaker after about 10 seconds. I can weld continuously if I plug it into my Miller welder/generator... so I guess it wasn't a total waste, there might be a time where I need to do flux wire MIG in the field instead of stick.
The length of the leads are the one thing i've consistently seen complaints about. Vevor also sells an improved version for a fair price, so I might make that upgrade and still come in below other budget brands. I'm excited to give it a whirl soon and see how it compares to my little lincoln
I still work with a 40 yr old Sears stick welder. It’s mounted on a special shelf about 8 feet in the air to the upper right of my garage door over the garage door track. I adjust it with a stick with a zip tie looped on the end.
I have about 60 or 70 feet of hot lead which reaches about anywhere I want to go from the shop to the back of my house. But I only have about 15 or 20 feet of the ground lead. When I was doing the step trailer for the Road Ranger, I clipped the ground clamp to a 20’ piece of aluminum angle iron, and laid it across a sawhorse where it touched another piece of aluminum angle iron, which then laid on the back of the trailer, held on with C-clamp.
If you don’t believe me, just look at some of my welds. Some people think I’m cheap when I tell these stories….
@Rick W if you run across short-ish pieces of welding cable you can get quick connects and make several pieces that you can assemble into whatever length you want.
https://www.amazon.com/dp/B0BXD6HNLW?tag=959media-20 <--- that's what I used, I bought a bunch of them
I have two stick welders, an old Century, and a Miller gas engine welder/generator. They have tapered female outputs but are not the same size so I made two sets of 2' pigtails with those quick connects on one end and the tapered end on the other. Then I took my existing leads and put quick connects on those too, so at minimum I have a 30' stinger and 20' ground. I ran across some more 10/15/20ft pieces of cable so I made a few more extensions. If I need to, I can go about 80-100ft out now but I don't have to have a very long, heavy, hard to handle cable.
I've welded a fair amount with mine using a 4000W Champion generator (3600W continuous I think) and just stick to around the 1/8" recommended settings and it seems to keep them happy...
Mine is a Generac 3250. I suspect it's just barely too small. I tried different settings though, even on the minimum voltage it'll still trip the breaker. It has a weird 13.5 or 14A breaker too... not the usual 15 or 20 like you'd have in a house. I'm kinda halfway thinking about upgrading to a slightly larger one, maybe a 4000w.
Ironically, the Miller machine that I can run it off of has a smaller breaker. I'm pretty sure it's either 10 or 11A and trips if it gets too hot, then auto resets when it cools down. I have never tripped that one.
Look at some of my welds. Some people think I’m cheap when I tell these stories….
Like this one?
It used to belong to my grampa, then my dad, now me....
I think mine is about the same size, but no gas fitting on top, and I don’t think it’s that fancy. But it looks like new, I don’t use it like you guys. My use runs hot and cold, no pun intended, I’ll do a bunch of stuff like I’ve done since I’ve known you guys, but sometimes it sits four or five years without flipping the switch.
The gold colored fitting is a magnet for the ground clamp to attach to, not a gas fitting. A lot of times much easier to get a good ground that way.
Good thinking, but I almost have the impression that you think I’m unhappy and skimping when I use 40 feet of aluminum angle. I actually learned that trick from some of the best welders in the world when I worked for a company that welded specialty metals on the test stands for the space shuttle engines, where they tested them. That project, and BTW, that company, came to an end when the Challenger blew up an 86.
Nothing wrong with that trick, I am just under the impression that you are a scrounger like I am and often run across things to bring home at very little expense!
Sometimes that wouldn't work anyway, I am working on building a metal door for a mine entrance right now that requires me to use all of my leads. I have to park the trailer down a small hill and around a corner. The long metal ground trick COULD work, but I would be awful afraid of something coming loose and starting a fire. Sometimes your method just wouldn't work well - sometimes mine won't work well - but if you can scrounge up some cable to make extension leads, why not have both!
Gotcha, and yes, I actually have seen some dirt cheap cable. At this point in my life, I never do anything outside the driveway, and I’m actually trying to get rid of stuff. You’ll understand when you get older. 😉
I am older. rather than understanding it's more a matter of ah, 'da hell wit it.
Featured Ranger Based Vehicle
