Couple items of note:
Welding up your own air tanks is high risk - if it fails, it is a bomb.
Simpler solution is to use propane cylinders. Pull the propane paraphernalia out, mount them upside down so no moisture accumulates and you have easy/low cost storage solution. Air coming out has...interesting...smell from the chemical they use to make leaking propane noticeable (And its been >35 years since we hung them). 100lb cylinders = 24 gals.
V-6 engine/compressor would be more challenging than what we did as the cam operates valve on both banks.
We have a Dodge slant 6 connected our compressor, which is a Chev Iron Duke. The cam gears in the 4 banger were replaced with a 1:1 drive, the exhaust drive train removed. As has been suggested, the spark plugs have been replaced with one way check valves piped into the air lines. A truck air brake valve prevents over pressure.
Clutch on the slant 6 engine allows starting the Dodge without the load of the compressor.
Even at idle, it compresses air at an impressive rate; little noisier than electric system though.
