Blackwidows 350 sbc street truck build
how it sounded. mind you i didnt have spark plugs or manifolds in at the time. wanted to build some oil pressure. yes i coated the cylinder walls with marvel before i cranked it
starter issue fixed. new transmission crossmember fabricated. and some engine detailing done. Here's more pics!!
Here is the adapter plate i installed to allow me to use the old style bellhousing mounted starter
The new starter
Detailed the valve covers.
Clear coated the intake
And got the engine sitting where i want it.
Just went through the whole thread. Looking good man! Can't wait to see this done and burning rubber. :3gears:
Not too much to update. been working alot. but figured id share the progress so far.
The transmission crossmember isnt bolted in yet. hence why its crooked.
ITS ALIVE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
CLICKY CLICKY CLICKY!!!!!!!!!
Got the steering shaft all pieced together and welded. And installed. No binding at all. It’s tight but has just enough clearance to allow for motor movement.
Pretty damn close to coming out of the shop and hitting the streets
He’s been MIA since about 2016. Nobody has heard from him since he last logged off
Wow. It appeared he spent more time on here than anyone.. I always thought he would be the last member standing. I hope he is ok.
Just finished up the build thread.. I am glad to see the Cragar SS wheels are still in the mix... In my opinion those wheels made the truck stand apart from others. Amazing job as usual. :drool:
