I have a 1994 Ranger 4.0L 4x4 with 170k on it and the A4LD transmission (also has 6" lift, 4.56 gears, and 33s for what it's worth). Runs fine, no problems, but it has high miles and I am thinking of the future.
I've read the tech articles on swapping in a manual. I am not a gearhead and will likely see if a transmission/custom shop can do this work. At a high level, are these the parts/steps needed to do the swap?
Need:
Steps:
I know it's not this simple, as I am sure installing all of the other parts to make the M5R1 work is a chore. Will the PCM from a '94 manual straight up swap with mine? Any differences in wiring or wiring harness? Any other big gotchas?
I don't beat on this truck much at all, mostly b/c I don't want to blow up the A4LD. Can the A4LD be built to be tougher, or is it just bad all around?
And I should buy a membership because this site is great
Thanks!
Need:
- M5R1 transmission
- PCM from '94 4.0L 4x4 w/ manual transmission
- Pedal assembly
- Clutch
- Any supporting brackets etc. for a manual transmission
Steps:
- Remove A4LD
- Install M5R1/clutch
- Install new pedal assembly and other supporting parts
- Replace PCM with one from 4.0L 4x4 w/ a manual
