- Oct 30, 2015
- St. Louis, MO
- My credo
- Well, that didn't work. Let's try something else!
To really figure out what the problem is, you're gonna have to do a few tests. It could just be a very worn out engine. So I would start by assessing the overall health of the engine.
A compression test will give you a good sense of that. Again, you can rent a compression tester from your local auto parts store. And by rent, I really mean borrow, because when you bring it back to them, they give you ALL of your money back. It's really great that they do this.
Testing compression is easy. First remove the fuse for your fuel pump and then start the truck. It will run for a second and then die. That's good. We're removing the fuel from the fuel system so the engine can't start. Leave the fuse out and remove ALL of your spark plugs. This is a good time to inspect your plugs. Plugs can tell you a lot about what's going on inside your engine. NGK has an excellent cheat sheet on their website here.
Now that the plugs are out, use the correct sized adapter for the compression tester and screw it into the first spark plug hole. Screw the compression tester into the adapter. Crank the engine for 5 seconds then view the compression tester. Write down the value and and then repeat this process for each of the remaining cylinders. Post the results here. Generally, you want to be somewhere around 120 PSI and all cylinders should be roughly the same. If you have one (or more) that are more than 10 PSI lower, then you have a hurt motor.
If you do find a cylinder (or two, or three...) that are lower, there's a couple places that compression could be going and there's more tests we can do to find out what's causing it.
I know I've thrown a lot at you today. I would do the compression test first. It's easy to do and tells us a lot about the condition of your motor and will help us determine where to go from there.
