odeek9
Hi-After owning this truck for 29-30 years one would think I wouldn't ask such a stupid question but here I am. Before I take it to a garage maybe someone can help me.
Beginning a few days ago I began noticing the coolant level in the reservoir was going down about an inch each day. Yesterday following an 80 mi. trip it had lost 1/2 of the coolant level only in the reservoir. I cannot find a leaking hose anywhere. From beneath there is a drip to a slight stream coming from somewhere between the engine and clutch housing. There's a thin metal plate there which it drips from. I can also see a bit from above at the back end of the area just below the valve cover. But it's inaccessible for me. And I can't find the drips origin! No oil in the coolant-no coolant in the oil. Truck runs fine except for a new rattle coming from the fan/radiator area that happens only for the first couple of minutes after starting. Belt is tight as are all pulleys. The truck never runs above 170.
Worried about the worst (cracked block or head gasket problem) I did a compression test and it's as always, 180-190 for all 4 cylinders. Is there any coolant that runs into the bell housing that could leak coolant internally that finally finds its way out? I don't think so but I'm no mechanic. Any thoughts PLEASE?
Thanks so much
Thanks so much
