I've a question for the welders out there, can the front caliper brackets be safely welded?
the reason I'm asking is to install 12" front rotors on my 11.25" equipped '05 Ranger.
Background info:
When Ford put the 12" rotors on Sport tracs and later Rangers they redesigned the steering knuckles to move the caliper mount holes out 3/8" to allow the 3/4" larger rotors. the calipers and anchor brackets are the same for both versions. for the 98+ torsion bar Rangers a swap of the steering knuckles is all that's needed for bigger brakes.
unfortunately for us 98+ coil spring guys there are no bolt-on part swaps to do this.
However:
there is a 12" rotor/hub that will fit the 98+ coil spring rangers, but the caliper bracket would need to be moved out 3/8" for it to work.
So, that brings us back to the question of the day:
can the caliper brackets be welded safely to fill the holes and add enough metal to drill new holes 3/8" closer to the bottom?
that is the only modification needed to put the 12" rotors on the 98+ coil spring Rangers. 2001 2wd Sport trac 12" rotors are a direct fit, use the same calipers & pads.
side note, will need bigger wheels to clear bigger brakes.
I'm in northwest Ohio and can travel a couple hours to anybody that wants to try this.
Perry
Background info:
However:
Perry
