- Apr 4, 2015
I have a '94 3.0L (Manual Transmission) 4x4 Ranger that I've been rebuilding. It has been starting just fine until last night. When I tried to start it, everything went dead - no dash gauges, no lights, no fuel pump sounds, nothing. I made sure the battery was fully charged. I put a volt meter across the fuse panel in the engine compartment and it reads 12.5V with nothing on. When I turn the ignition switch on, the voltage drops down to 0.5V. When I turn the switch off, the voltage jumps back back up.
Trying to track down wiring using the Haynes Manual is nearly impossible - they don't even list the fuses I have in my engine bay fuse panel. I've tried pulling the 3 relays in the engine bay fuse box (fuel pump, PCM power and AC WOT), but still get same results. Have also tried pulling all the fuses from both fuse panels (engine bay and interior), but can't seem to isolate what is drawing down the power! I've tried disconnecting the alternator power wire just in case it was shorted diodes with out any luck.
Can anyone suggest where to find a better wiring diagram, that actually shows power connections in the fuse panels, along with actual switch contacts? Boxes with wires going in/out but no other details don't help much.
Any other suggestions on what to try/test?
