My 91 ext cab build thread
lol i saw that explorer on CL a few times. was consideirng it for a 4l swap in my ranger
She's got the notorious valvetrain tick. It's pretty bad lol. But its only got to last me about a month, or probably shorter so not so bad. Might just part it out after and buy one in better shape. I want my next project to be a first gen Explorer. This one's just a little too rough around the edges for my liking lol
yeah it looked pretty uncared for - being a mechanic i cry everytime i work on a explorer or ranger, they are all in such bad shape. i dont think ill ever find a 4l im happy enough with without rebuilding it.
Thats how it starts. I got a couple parts trucks sitting around from the same thing.
Yeah regular maintenance as well as owner intelligence is key lol
More parts!
Got my new clutch kit and clutch slave cyl.
also got my manifolds drilled and tapped.
correct me if im wrong but, for a flywheel, i need a 157 tooth 28oz right?...
Parts!
Got some more parts for the Forest Ranger!
Water pump. T-stat housing. Fuel pressure reg. Clutch master. and i pick up the oil filter adapter tomorrow.
I actually have to return the fuel pressure regulator tomorrow because I got the wrong one. They gave me the holley 12-803, which is a non-return style. I need the 12-803BP, which is the bypass/return style. Wondered why it was so cheap... lol.
I heart pick a part
Found a Taurus fan at the local yard. As well as some rad support brackets. and a nice mech fuel pump block off plate.
Somebody robbed the good rad support :|
And more parts!
Got a stock 4brl intake all blasted cleaned up and painted for $40.
And a rebuilt 1850 Holley 600cfm carb with brand new in box choke cable for $90.
Got the right fuel regulator, as well as the oil filter relocation kit with the 90 degree adapter.
:icon_confused:
ya know.....for 50-100 bux i can go to the junkyard and put an efi system on a windsor....
:icon_confused:
Wow. Must be cheap prices at your junk yard eh. (here is our junkyard price list http://www.pickapart.ca/price-list/ ) I'm goin efi next year when i build the 408w. That was the plan in the first place, but that got put on the back burner for now because i want to build it right, but that takes money and time for how i want to build it. And also I love the classic carb engines. Its not always about what makes the most sense for me. Its about what i like, and a 4brl holley sittin atop a ford v8, is a beautiful thing. The efi is comin though.
The swap has been put on hold because the place i was going to do the swap is no longer available to me. so the Outpost Explorer build will be the main focus for a while because i need it reliable as my dd.
finished up the rad support brackets and got a plug wire set
So... I think I'm gonna go with a c6 trans now after much thought...
Sold the zf5 and bought a C6
looks like a fun project. I just got done putting that exact body lift in except I went 3 inch lift, the 4 cab bolts fought me the whole way so I brought out the half inch breaker bar and a chunk of pipe.. good luck with your install
Event Coverage
TRS Merch
