I wonder what would happen if I put the original vent back and put a piece of hose between the 2? Maybe even a tee fitting in between? Maybe I'm over complicating things lol
How close is the fluid level to the vent hole? I would think you would want the vent as high as you could get it.
I'm telling you man, high vent, catch can and 1/2 quart oil is the key I think.
You might not even need the catch can, just run a vent line up the firewall first and see how much that does for you.If it still pukes, add a catch can to the vent line and never worry about it again
I finished my Painless adjustable fan controller install. It was super easy and so far works great.
Oops forgot to mention that. If you look at the pic it's at the very bottom near the yellow cap. Or you can just follow the metal wire/tube thingy from the assembly.
With the zf5 swap, what are you using for the master cylinder and lines? I read through your thread but I was confused what parts were ranger and what parts were not.
