Rgrove03
- Apr 9, 2014
I recently purchased a Baja Bug with a 2.3L ford engine. Being the non-experianced and mechanically declined person I thought I was'nt I need help. I pulled the valve cover and pan off. Verified it has .030 over forged pistons and H-beam stroker rods. I replaced all the gaskets and such. I then decided I needed to replace the old looking timing belt. Needless to say my 4 year old decided to turn the distributor pulling around and around while I was opening the new belt. The crank and cam pulleys are in the same position as when I took the belt off. The motor being an essinger offroad edition has no timing mark or timing cover for that matter. It does have an underdriving pulley and adjustable cam pulley on it. Any help would be appreciated. Is there a was to line up the other pully and just put the belt on and go? help!
P.S. I'm assuming my oil pump pully drives the distrubutor?
