Sorry it took a year to reply............
Happy New Year
Boy, that is weird, 10 to 65, can't see fuel pump issue, even check valve issue would be hard to diagnose from that.
Just because it is easy, at the end of the fuel rail there is the Pulse Damper, it will have a vacuum line attached, pull that line off and smell it foe a gas smell, it should not have a gas smell.
Another thing to try, Computer controlled engines have a WOT(wide open throttle) routine for startup.
When gas pedal is pressed to the floor the TPS(throttle position sensor) is sending max voltage to computer(above 4.5v) this tells the computer to disable fuel injectors while cranking engine.
This routine is there to clear a flooded engine.
So next time you try to start cold engine or warm engine for that matter, before turning on the key, push gas pedal to the floor and hold it there while cranking, engine should NOT start since no fuel will be available.
If it fires a bit then there is fuel available in the manifold, where it is coming from???
And just to confirm normal startup, besides the long crank time:
When key is turned on a few things happen:
The IAC(idle air control) valve is opened all the way
Fuel pump comes on for 2 seconds
ECT(engine temp) sensor is checked for cold or warm engine
When you start cranking:
pulses come from crankshaft sensor
there is about a 1-2 second delay, after pulse is received, before spark and fuel injectors are started, this is "said" to be done to pre-lube engine, if they were worried about that why not just add a pressure sensor to oil passage, lol, oh wait they already have one.
anyway once engine starts RPMs should go up to 1,500+, IAC valve is open all the way
computer then closes IAC valve to set idle at 1,000rpm cold or 750rpm warm
So idle should drop after startup
Does your system work that way?
