OilPatch197
- Sep 23, 2007
- Age
- 96
Had chaffing on the 8 gauge charging wire from the alternator to starter on a GM Buick Regal.
The wire rubbed itself bare and burned in two! I had to fix this car, so I thought this would be easily, just splice the wires back together....
RIGHT! ...NO!
So I look in my electrical supplies, I had some crimps for 8 gauge wire from a subwoofer install kit, but my crimper only did 10 gauge and higher!
So I attempted to use the crimp with the crimper pliers, it did not hold. So I had a household 4-8 awg gauge splice kit you inset the wire and tighten the set screws and cover with heat shrink tubing.
I was worried that the screws would vibrate loose, so I had another option, split nut splices, and that is what I used, tightened it down and wrapped it like mad with electrical tape.
So my question is what should I use to splice this? I had to use what I had on hand, and would like to "do it right" I just don't see anything at the stores for automotive wire smaller than 10 gauge unless it's some stereo kit.
RIGHT! ...NO!
