- Sep 3, 2010
- Largo, Fl
- My credo
- None
At this point the doors and fenders have been aligned with the rest of the body as close as possible. The final adjustment of fender/door panel transition can be finished up with a sanding block. During the body prep and paint stages the fender panels and doors will be removed and reinstalled multiple times. To make it easier to return these pieces to the exact same location small alignment holes are drilled through the fender edges and door hinges and removable alignment guide pins are fit into place.
