My ranger has a hard time starting there are no codes
JMRanger03
Hello i was wondering if anyone could help me with this problem. the fuel pressure is good running at 65 psi. but it was starting up normal about a month ago with no problem. Now it is hard to start. there are 0 codes i even put the scanner on and drove around and still 0 code.. Also it hesitates when i drive sometimes.kind like a bucking loss of power and them all power is good if i back off the gas.
Thanks JMRanger03
When was the last time you did a tune up or checked the battery? Your hard start could be an old battery starting to give up.
Your bucking sounds like a misfire. Old plugs and or a weak coil could cause both of those. If your scanner does mode 6 data look at that and see if the monitor has recorded any misfires. A miss won't always set a code.
^x2 I recently had a similar problem, turned out to be a coil that was intermittently failing and not throwing codes at all. It wasn't until I tested each wire at the plug end, then found a dead wire, then tested it at the coil and found that the coil wasn't firing fast enough on that one lead. A new coil and I was running good again.
