Got new battery, starter just clicks.
pobrejuanito
10+ Year Member
Hey Guys,
I have a '85 Ranger 2WD. The starter "clicked" when I turned the key. I tried to jump it but I heard consecutive zapping sounds. I took the battery in to test and the guys said the battery is dead. It was from '11/08. I got a new battery, installed it and it started right away. After few days later, I tried to start it after an oil change, the starter just clicks now. I check the volts and it is 12.58V. There is no amp draw I don't think.
What do you guys think it is? Bad starter?
bad cable connection somewhere. Start with the connections at the battery and go from there.
could be bad connection, solenoid or starter.
check all connections if good i would start with the $12 solenoid mounted near the battery this is a notorious ford issue. if its not a connection issue or the solenoid your starter is bad. ( dont forget to check ground wires not just the positive wires)
easy way to check the solenoid is to make it just "click" leave the key on and cross the 2 main wires on the solenoid with a screwdriver (the sparks wont hurt you so dont jump :P) if it starts the solenoid is your issue
I'll try to replace the solenoid tomorrow night and report back
I tightened secure all connections but no go. I'll try to replace the solenoid and post back tomorrow night.
Thanks for the advice.
Hey Guys,
New battery should be above 12.7vDC, closer to 13vDC
When batteries get below 12.5vDC after engine has been running, it is on it's last leg.
Your alternator is not charging the battery enough, or wiring is bad.
With engine running battery voltage should show 13.8vDC, that is the alternator's voltage to keep battery charged.
If voltage with engine running shows 13.4vDC or less then alternator needs to be replaced.
I would jump it and it should start, but starter and solenoid could have been effected by the alternator and older battery issues.
When amps are low because of battery being low the starter and solenoid seem to heat up a bit more and since they are older they can end up having problems.
Like a domino effect.
But I would definitely have the alternator checked.
Pretty much what Ron said. Also, FWIW, since I started using the dielectric grease on the terminals, I've noticed I have had a lot better luck with connections.
Replace Solenoid
Hey Guys,
I replaced the starter solenoid and the truck started right up! I checked the voltage with the engine running and it's about 14.5V, so I guess the alternator is working. The battery cables don't look good so I may replace it.
Thank you for your help.
Hey Guys,
'85 with original battery cables....change the positive cable & both negative cables(the negative cable may be a 2-piece cable....they can corrode on the inside & you won't be able to see it)
