- Mar 28, 2009
- Age
- 36
Hey guys, I am trying to change the timing belt on my 83 2.3L ranger. The old one snapped. I have everything taken off and already replaced the tensioner, but now what? I can't find a tutorial anywhere about lining the engine up to put the belt on. I spun the cam pulley to make sure it's still spinning freely and it is. The pulley has a mark on it and my timing cover (plastic front and back) has a spot to line it up. It takes 4 turns of the cam pulley 4 turns for the lines to match again. So when the lines match up, does that mean that the engine is at TDC? Also, is there anything else I need to line up before installing the belt? The timing belt goes from my cam pulley to I believe the water pump or oil pump (not sure but when I rotated it, it sounds like its pumping some type of fluid). Does the harmonic balancer need to be lined up at all? And what about the crank pulley. Please help, my truck is my daily driver.
