Escorts 2nd SAS
My local jy has like 4 or 5 early broncos sitting that are basicly untouched, not to mention all the older ford trucks they have too.
Sent from my SGH-T499 using Tapatalk 2
Looks like I need to make a trip to your area.
Sent from my PC36100 using Tapatalk 2
It has about any older vehicle you can think of there, even a duce and half just sitting. I think I get deals when I go there just because they know me, they let me wonder the place by myself :D
Been busy last two days. Yesterday went to the Take-a-Part to get some WJ knuckles. There were a few there but was hoping to get a complete set( calipers, rotors, etc.) but nothing looked good. So instead I got a power steering pump bracket for the 4.0L so I can modify it to fit a Saginaw pump. Not sure if I can make it work or not.
Also, found a Sport Trac with a driveshaft in it, but once I pulled it, I noticed it was bent from the forklift.
Also yesterday, I got the argon tank filled for my brother's mig welder, and then made a cart for it.
Today I started making a new bracket for the pump, don't think I will be able to modify the stock one. So I'm not sure if I want to try and make one.
Sent from my HTC ONE S using Tapatalk 2
That Guy is making brackets to adapt the canned ham Saginaw pump
You are correct. I wanted to see of I could make it work, so I just might have him make me one. I just don't have the money right now....
Never ending cycle huh?
Wait if your going hydro assist, why are you going with a saginaw pump? Can they run hydrolic fluid or am I missing something here?
Power steering fluid/ATF is hydraulic fluid.
-PlumCrazy
Well, the Ford pump sucks. You can't modify it for more pressure or increase the flow, bit the Saginaw you can....and this is what I have already done to my Saginaw pump sitting on the bench.
Oh, I've been tinkering around with some scrap pieces of steel laying around and I think I have made a bracket that will work. I need to go get some more o2 since its empty to finish it.
I use flux core. It welds better for me and isn't as picky when it comes to the wind and whatnot blowing the shielding gas plus is cheaper, at least for me, to weld with.
Event Coverage
TRS Merch
