99 Ranger build
I have a Auto transmission, wish i had a stick shift.
how the heck did that caliper set up cost you $400? i just priced out everything and its less than $200
Sorry I was just guessing. I added what I put in to mine came out to just alittle over 300.00. That with new rotors,loaded calipers bracket for conversion,banjo bolts and brake lines.
Oh ya. You got steel braided. Those aren't cheap. For your front axle, did you do it the same as the rear? Meaning both caliper lines meet at a T in the center and go straight up? I wanted to do that for a clean look but I haven't seen anyone else do it so idk if it's a bad idea
so.... When you actually going to wheel this thing? :thefinger:
Its pretty much a mall crawler right now. Need to swap my rear gears yet, modify my crossmember and get a front drive shaft.
Got my front bumper on. Got the bumper from RLC welding. Really good work and will definitely will order from james again. Heres some pics i just took
99 Ranger build
99 Ranger build
99 Ranger build
99 Ranger build
99 Ranger build
Looking good!! What kind of welder u plan on getting? I went with a hobart 187 and its the best welder i ever had and well worth the money.
Getting a buzz box. Wish I could afford a mig strong enough to do 1/4" steel. That would make life so easy
That is a sweet looking bumper. Very nice how it just flows into the front crossmember. Buying a winch for that empty spot?
Thanks, was thinking about a smittbilt 8000lb winch, but thats a ways off unlees i come by a good deal on some other winch.
damn! Truck is looking great man.
