- Oct 1, 2009
- Raleigh, NC
looks good....that a sterling in the rear?
Thanks, Nope i got a Dana 60 in the rearlooks good....that a sterling in the rear?
that truck is amazing. turned out great. by far the most inspirational thing keeping me motivated to finish my truck. how tall were you able to get that front tire off the ground? enough to climb up on a 37" tire?
it seems like your rear end could be a little softer. you still got a few more inches to stuff up that rear tire
thanks , i will.take some measurements and save them because i bet that youll gain at least 5 more inches of uptravel once they break in. then maybe a longer shackle up front to make up for the sag, giving even more down travel. this thing is unbelievable
Thats the plan.gotcha, that would've been my next guess.
that bumper is much beefy, wake up early and get that damn thing installed![]()
Theirs no hook up for the e-brake for the conversion that i did. I think their is a differnt caliper that u can use for the e-brake conversion. I think is was around $400.yesterday i woke up at 6am to beat the heat and to start removing the d60 from the donor and im wondering if the ebrake will swap over. i know your running disks but did you happen to see if the ebrake was interchangable? also, how much did the disk conversion cost you?
